03-27-2007 12:28 PM - edited 03-14-2019 08:43 PM
dear folks,
i have two routers one 2800 and 3800.
3800 is at main site and 2800 at remote branch.
now what i want is to make phones at remote branch(2800) to register at the main site(3800). and all calls should go through main site(3800)router for thatwe have a lease line between these routers of 128kbps. i have proper connectivity between two sites as i can reach all IP address in other side.
your suggestions will be highly regarded.
03-27-2007 12:55 PM
any help there..
03-27-2007 01:39 PM
Are you using DHCP at the remote site? If so, did you setup the Option 150 for your Cisco TFTP server? Are you getting any error messages on the phone at the remote sites?
03-27-2007 01:49 PM
thanks for speedy reply,
we are using the DHCP at remote site.
the cisco phones are getting the TFTP if i connect it to the remote router only but i want it to use the main site for registering.
so that it will call from main site.
if i give the TFTP server IP as the main site TFTP server then it will keep on showing configuring ccmlist.
03-27-2007 02:00 PM
So are you saying the phones will register at the remote site if you use a TFTP server that's at the remote site? But if you put the TFTP server of the main site, the phones won't register?
From the remote site, can you ping the TFTP server of the main site?
Can you give examples of the scheme of your IP subness,subnet mask and default gateway at the main site and at the remote site?
Are you phones set to auto register or do you have them already in CCM?
03-28-2007 03:31 AM
its possible guys...
finally m done with it.
the phones are getting DHCP from branch office and getting registered to main site.
what i did is i configured telephony services for branch router and put all things for tftp ,router ,default gateway as branch router.
after the phone is up i changed the tftp statically to main site and its working fine.
thx for ur support .
03-27-2007 04:06 PM
set the option 150 command to be the tftp at the main branch. for instance
main site
call manager publisher = 192.168.32.1
call manager subscriber = 192.168.32.2
remote site
on the route or switch in the dhcp config use the option 150 command and specify the call manager tftp server at the main site of 192.168.32.1
then the phone will load thew config from the main site and hopeully register there.
03-27-2007 11:37 PM
first of all i want to make it clear that its not call manager its CCME.
i tried putting the tftp of the main site but its not coming up its showing "configuring ccmlist".
can i do one thing that the IP phones can take any but the TFTP it should take from main site??.
i will try this again but i have tried this its not coming if u have ny more ideas then ur most welcome.
03-28-2007 01:05 AM
I don't know if is it possible a phone located to a branch office could register with a CCME in a main location.
Some time ago it isn't now i don't know
03-28-2007 03:57 AM
Absolutely possible.
What you have to do is check that the IP network is OK. After that connect the IP phone and it will register, if it doesn't something is wrong in the network configuration.
03-28-2007 08:13 AM
but u have to make sure the version of ccme is above 3.3
there is lot more to do in this ..now as i have to make the calls to use less bandwidth. if i call from too many phones they start deregistering which is not acceptable.
but overall thanks again for all of your support
03-28-2007 11:15 AM
ephone xxx
codec g729a
that's it!
