Registering SIP dlink dph-300s on CCME 4.1
Hello all!
I try register Dlink Sip Phone on CCME.
The part of my config is:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol none
h323
modem passthrough nse codec g711ulaw
sip
registrar server expires max 1200 min 300
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
mode cme
source-address 192.168.0.231 port 5060
max-dn 20
max-pool 10
authenticate register
time-format 24
date-format D/M/Y
voicemail 90
file text
create profile sync 0246360689430548
voice register dn 5
number 5005
allow watch
name 5005
label 5005
mwi
voice register pool 5
id mac 001B.111E.1D42
number 1 dn 5
dtmf-relay rtp-nte
username cisco password cisco
codec g711ulaw
But then I try register phone I receive error message:
*Mar 23 08:33:38.063: VOICE_REG_POOL: Register request for (5005) from (192.168.
0.46)
*Mar 23 08:33:38.063: VOICE_REG_POOL: key(A50C0FED00035331) added to nonce table
*Mar 23 08:33:38.063: VOICE_REG_POOL: Contact doesn't match any pools
*Mar 23 08:33:38.139: VOICE_REG_POOL: Register request for (5005) from (192.168.
0.46)
*Mar 23 08:33:38.143: VOICE_REG_POOL: Contact doesn't match any pools
*Mar 23 08:33:50.527: EVENT: 1 node in nonce tree obsolete
*Mar 23 08:33:50.527: VOICE_REG_POOL: deleted key(61D04DE200033B5C) from nonce t
able
*Mar 23 08:34:01.503: VOICE_REG_POOL: Register request for (5005) from (192.168.
0.46)
*Mar 23 08:34:01.503: VOICE_REG_POOL: key(03BDBE8100035C59) added to nonce table
*Mar 23 08:34:01.503: VOICE_REG_POOL: Contact doesn't match any pools
*Mar 23 08:34:01.583: VOICE_REG_POOL: Register request for (5005) from (192.168.
0.46)
*Mar 23 08:34:01.583: VOICE_REG_POOL: Contact doesn't match any pools
Can any help me to resolve problem?
Thank you very much..
Hall of Fame Super Gold
Re: Registering SIP dlink dph-300s on CCME 4.1
set username, now "cisco", to be same as number, that is, 5005. If the phone is local on the cme lan, username is not needed, mac is enough. If it is remote, mac doesn;t matter and can be all 0s.
Thank you very much!
All works fine. The trouble was dead ip-phone. I have changed ip phone and all works fine.
You are welcome. Remember to rate useful posts with the scrollbox below!
752
