Registering SIP Phone on CME over WAN
Dear NetPro gurus,
One of my clients trying to register his Cisco 7945G SIP Phone over the WAN.  His Cisco phone managed to show the 'text label' as well as the extension on the phone, but it keeps showing as "Registering" and never actually registered.
On the CME router, we can ping the remote Cisco 7945G SIP Phone fine without any packet loss.
br-orange-1v#ping 10.69.22.140
Sending 5, 100-byte ICMP Echos to 10.69.22.140, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/5/8 ms
br-orange-1v#
And here are the configs for the SIP Phone:-
voice register pool  28
fastdial 3 00478488565 name PeteMobile
id mac 2C3F.38C9.9D3B
type 7945
number 1 dn 28
template 1
cor incoming CSS-STD default
dtmf-relay rtp-nte
voice-class codec 1
description Chris's 7945G
no vad
voice register dn  28
number 82133
call-forward b2bua busy 82199
call-forward b2bua noan 82199 timeout 20
allow watch
name Chris's 7945G
label Chris's 7945G / 82133
We have already done a "no create profile" and followed by a "create profile" under voice register global, but it didn't helped at all.
I have spent a lot of time on this already so would greatly appreciated if anyone can shed some light on this.
Cheers,
Hunt
Everyone's tags (7)
Blue
HI Hunt
Use "username XXX password XXX" comand under voice register pool.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak,
I did that as per the updated config below, but it is still stuck at "Registering".  And I did a "no create profile" and followed by a "create profile" but still no luck.
fastdial 3 00478488565 name HuntMobile
type 7945
number 1 dn 28
template 1
dtmf-relay rtp-nte
voice-class codec 1
username Chris password cisco
description Hunt's 7945G
no vad voice register pool  28
type 7945
number 1 dn 28
template 1
dtmf-relay rtp-nte
voice-class codec 1
no vad
Hunt
Blue
HI
Send us full router configuration.
Ronak Patel
Hi Ronak,
I have just uploaded my full router configuration on my original post.
Thanks so much for your help in advance.
Hunt
Blue
HI
I can see following missing config
sip
bind control source-interface
bind media source-interface
Is there any firewall in between??
Ronak Patel
Rate all helpful posts by clicking stars below the answer.
1151
