Registration Rejected: Security Error
I saw a couple similar posts, but no resolution...
I have a simple Sub/Pub cluster running 7.1(5).  7945's and 7965's with SCCP45.9-0-2SR1S register fine with Pub, but I get "Registration Rejected: Security Error" trying to register to Sub.
Thoughts?
Todd
Green
Re: Registration Rejected: Security Error
Are you running security?
Have you tried deleting the CTL file?
Let us know
No security enabled...  It was actually due to the databases not fully replicating.  Had a DNS issue.  Once the replication was clean, it was able to register with the subscriber.
You have dbreplication issue between CUCM Publisher and Subscriber.
to resolve it, enter in CUCM Publisher console then use the command utils dbreplication stop all that will took some time then when will finished use the command utils dbreplication reset all.
Wait untill the dbreplication of Publisher and Subscriber will complet (use utils dbreplication runtimestate to see it) then register your phone in Sub.
Best Regard
I saw this same problem.  I had extensions 2000-2500 setup to auto register new phones.  After the first part of the large deployment, I started to see this problem.  I checked the dbreplication and that turned out good.  It turned out that all of the extensions for auto-registration had been used and the Call Manager tombstoned all of the extensions.  Once I went to the route plan report and searched for unassigned DNs, I found all of the numbers in the pool.  Once I deleted the unassigned DNs, I was able to auto register.
Hope this helps someone else.
Tom
2969
