Registration status in CCM 3.3(5)
aboelhouwers
I have the following problem in a 3 CCM 3.3(5) cluster consisting of 1 publisher/subscriber and 2 subscribers, using 2 different callmanager groups.
Most telephones are registered in Callmanager but if telephones are added to the second callmanager group, they work but have a not registered status in the CCM Administration.
Someboy of you is familiar with this problem and even better is there a solution.
See also the attachment.
TIA
Aad
Rob Huffman
Hi Aad,
Look for the differences in the 2 CCM Groups. Are all 3 servers (1 Pub and 2 Subs) in both groups? Is there a problem with the DB sync between the first CCM in the non-working group and the Pub?
Let us know.
Rob
Hi Rob,
Yes in both groups same servers, only the order different. The problem is only related to one specific server. For your information
Grp 1: server 1, server 2, server 3
Grp 2: server 2, server 3, server 1
Grp 3: server 3, server 2, server 1 (problem)
Grp 4: server 3, server 1, server 2 (problem)
the problem is again the registration status, the telephones themselves work fine. In the network config screen on the telephone itself or via the web interface it says: server 3 active, server 2 standby, server1 or server 3 active, server 1 standby, server 2 (depends on grp 3 or 4 chosen).
By the way how do I check the DB sync?
Rgrds
Aad
