regualer Voice Mail machine for CME??
jolo07310
Level 5
Level 5
I am not sure my idea work ot not...
If I have 2811 with CME feature set, also, with VIC2-4FXO(PSTN), and VIC2-2FXS (Voicemail machine).
Can i use regualer voice mail machine plug into FXS port?? I mean I dont want to buy AIM-CUE or NM-CUE, coz it is so expensive.
Anyone done that before??
Dial-peer voice 1 pots
description FXS
destination-pattern 1001
port 0/0/0
ephone-dn 1
number 1002
forward-noan 1001 timeout 10
forward-busy 1001
Telephone-service
voicemail 1000
Ken
paolo bevilacqua
Sure, will work, if the machine makes use of caller-id, you can send that as well.
but check-out that aim-cue with the minimum license set is quite competitive for the same number of users.
Hope this helps, please rate useful posts!
