Silver
Reinstall Subscriber
I have the following.
Cluster 5.1, but original install DVD is 5.0.
Now I want to reinstall the sub, but the pub is on 5.1 and the install DVD is 5.0
I do have the Upgrade patch 5.1
Can I install the sub using 5.0 and then upgrade to 5.1 and resync the database?
Or do I need now 5.1 install DVD?
Any idea?
Jan
1 ACCEPTED SOLUTION
Super Bronze
Re: Reinstall Subscriber
You should be able to boot from the 5.0 media, and will then be prompted whether you wish to install a patch during the install. Point this at your upgrade file on an SFTP server.
This works for all the versions I can remember, hopefully it wasn't something introduced after the 5.0 release!
Boot it up, you should find out pretty quick.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Aaron
Silver
Yeah, you are right, never tried it though.
I shall see tomorrow,
Jan
Silver
232
