Reinstallation of UCM 6.0 BE- Procedure
Hi we are running UCM 6.0.1.2000-3 BE.(MCS7828I3-K9-BE)
We are facing some unity connection issues and we are planning to re install .
Can some one help me about reinstallation procedure and other points needs to be taken care before reinstallation.
regards,
Silver
Re: Reinstallation of UCM 6.0 BE- Procedure
Upgrading System Software
Before you upgrade the software version of Cisco Unified Communications Manager, verify your current software version.
To do that, open Cisco Unified Communications Manager Administration. The following information displays:
"Cisco Unified Communications Manager System version
"Cisco Unified Communications Manager Administration version
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/rel_notes/6_1_1/cucmbe-rel_note-611a.html#wp290988
there is nothing particular about a reinstall, if you're going to wipe out the system just write down the hostname, IP addressing, etc
if you're going to restore the info just make sure the backup was completed successfully and verify it's up to date because any changes made after the backup is done won't be on the file
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
107
