07-01-2008 01:18 PM - edited 03-15-2019 11:40 AM
Can i reinstall the Call manger server with the CD as described(Unified Presence 6.0 Software - available with CCM)that came with the server
07-01-2008 01:35 PM
it sounds to me that what you have is CUPS and not CUCM on that CD
javalenc
if this helps, please rate
07-01-2008 02:17 PM
You should have received a DVD that has CUCM6, CUCM-BE & Unity Connections.
You use this DVD to rebuild the system.
Hope this helps,
Gary.
07-01-2008 02:40 PM
how do i receive it because it did not come wioth the server
07-01-2008 05:37 PM
you need to reach customer services or use the PUT to get the media
javalenc
