Reject translate rule
Hello
Have CME 7.1 and sccp phones on it with 17000-18000 and 500-600 numbers on it.
I trying to reject calls from 17000-18000 to 500-600 and 500-600 to 17000-18000.
voice translation-rule 17000
rule 1 reject /.../
test voice translation-rule 17000 500
500 blocked on rule 1
voice translation-profile 17000
translate called 17000
ephone-dn-template  1
translation-profile incoming 17000
ephone-dn  2  dual-line
number 17815
label xxx
name xxx
If I call from 17815 to 500 call don't rejected. Advice, please, where I'm wrong?
Thank You
So you are trying to block internal calls... I would recommend using Cor lists
Check out
https://supportforums.cisco.com/thread/2017450
Re: Reject translate rule
Thank You, I'll check, but in this case I don't understand the next:
if I change
rule 1 reject /.../
to
rule 1 /^[012346789]/ /5/
it's working to internal calls..
For internal calls not working only reject rule, I understand correctly?
I read, but they have two routers and dialpeers to second router with outgoing core list. I don't have second router, all phones on one router. Or I something don't understand?
137
