ā11-28-2011 03:08 AM - edited ā03-16-2019 08:15 AM
We have one requirement to forward the call to Number in particular time.So, i just wanted to know can we have an option available in call manager to forward the call in particular time.
Its urgent,need your help.Plz
Solved! Go to Solution.
ā11-28-2011 03:28 AM
You can accomplish this with Time Periods/Schedules. The general concept is that CUCM will activate a Partition - and the translation patterns it contains - in accordance with the time schedule you specify. In your situation you could add a partition with a translation pattern that forwards calls to that destination elsewhere. The time schedule attached to the partition will only make that translation pattern available in the CSS within the specified periods. When the partition is inactivated per the schedule the call will ring through to the normal directory number. Just be sure to use Urgent Priority on the translation pattern or place the Partition above your normal DN's partition.
Time of Day Routing:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/a03tod.html#wpxref46259
Please rate helpful replies.
You will need to look at Time Day Routing
I do not know which version of CUCM you are running.
Here is a link for ver 7.1.3
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b03tipd.html
You will need a T.O.D partition
A TOD css etc
Alex
ā11-29-2011 06:24 AM
Thanks for this information,can we have another option from Remote destination in call manager?
