relay fac from PRI to BRI
I'm designing a new CME implementation with ether UC560 or ISR2921. we have a PRI line where we recieve voice and fax, and an internal fax server with BRI card.
Is it possible to configure relay for specific call comming on PRI card (based on called number) to a BRI interface connect to the fax server?
Any configuration exemple is welcome!
1 REPLY
Green
If the FAX calls are incoming on PRI straight to BRI then there is NO voip therefore FAX relay or passthrough are not involved
If the calls to fax are all to a dedicated called number then you should be able to capture these with dial peers.
Something like this:-
dial-peer voice 100 pots
description *** FOR INCOMING FAX CALL MATCHING 4321 ***
incoming called-number 4321
direct-inward-dial
port 0/0/0:15
dial-peer voice 201 pots
description *** FOR INCOMING FAX CALL MATCHING 4321 TO BRI ***
destination-pattern 4321
port 1/0/0
pref 1
dial-peer voice 202 pots
port 1/0/1
pref 2
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
149
