Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Release document needed.
Hello guys, does anyone have the release document for  Unity Connection Version 7.1.5ES7.10000-7. I am trying to find out which bugs are fixed in this Engineering special.
Cheers guys.
Hall of Fame Super Silver
ES release notes are available upon request from TAC only.  They do not get posted anywhere.
HTH,
Chris
Re:Release document needed.
Is there a specific bug you have in mind and I can verify if its fixed or not in the version you are requesting
Sent from Cisco Technical Support Android App
The bug Ids are bug ID CSCtd45141 and bug ID CSCtq67899.
Thanks for your help.
CSCtd45141 :- is already addressed in 7.1.3 ES for Unity so should be addressed in the 7.1.5 train
CSCtq67899 :- is addressed in Unity Connection 7.1.5 ES 54
Hope this helps
Niket
Thanks for the info.
329
