Community Member
Remote Aim-cue aa not running for pstn incoming calls
Hi all,
I briefly describe my scenario:
Main site with UCM 4.2.3sr2 and voice gateway Cisco 2811 with Aim-Cue 3.0.1 on board, completely up and running for main site use an for remote voice mail use also from remote sites (I'using transcoding).
3 remote sites with Cisco 2801 srst connected in vpn using Pix firewalls everywhere.
I would like to make available for branch offices an AA service provided from Aim-cue present at the main site.
Transcoding seems to work correctly, infact I'm already using it for voice mail also from remote sites.
from remote site, if I call pilot no. of the AA script, works fine, THE PROBLEM COMES when I redirect using num-exp the incoming calls from PSTN to the AA pilot no. It doesn't works, infact call contact the correct dial peer, ring once, then takes redirection to PSTN again and the carrier provide a "non existing number" message.
I can provide configurations and debugs.
Thanks a lot for your help.
Emanuele
Community Member
Re: Remote Aim-cue aa not running for pstn incoming calls
how are you terminating the calls from the PSTN, have you tried using connection plar to a dial-peer that holds you CUE AA pilot number, I have this working at several locations see sample below
voice-port 0/2/0
no non-linear
playout-delay maximum 120
playout-delay nominal 15
playout-delay minimum low
timeouts interdigit 2
timeouts call-disconnect 2
connection plar opx 6701
dial-peer voice 6700 voip
destination-pattern 670.
voice-class codec 1
session protocol sipv2
session target ipv4:[IP address of CUE]
dtmf-relay sip-notify
no vad
Community Member
thanks for your answer, I just tried your suggestions but doesn't works yet.
I would like you take a look to my show runs (RTMI01 is the router with AIM-cue aboard standing at the mail office in Lan with Call manager).
RTRM01 (is one of the remote branch office routers) with no Cue modules at all.
Community Member
Hi jbiggs,
the config you will see, don't contain the modify you suggested me, this is just because I took it before your email. But that is the only difference between the files and the test I did after it.Infact I did it using connection plar
Thank you
Emanuele
153
