Remote Destination as OCS-Client
I have probem with CUCM 7.1.3a and mobility/remote destination.
scenario:
Phone A  (dn = 1000)
Phone B (dn = 1001)  with  two remote destinations  (mobile/gsm and OCS Client)
I configured 2 remote destinations for  remote destination profile B
First remote destination points to a mobile/gsm phone => this works !
Second remote destination e.g.  "9010"  points to:   route pattern  (90xx) => route list  => sip trunk to MS  OCS
but   the remote OCS Client doesnt ring !
If  I call from phone A  (dn = 1000)     directly  to the corresponding OCS dn  (9010)  =>  works !
I checked  rerouting css  etc. ... its ok ,  OCS-dn (Route pattern)   and  phone-dn  are all in the same enddevice partition
my question:
Is mobility/remote destination compatible with SIP-Trunk to  e.g. OCS ?
or does mobility/remote destinatin  only support "classical"   H.323/MGCP  TDM-PSTN outbreak ?
kind regards
Michael
1 REPLY
Re: Remote Destination as OCS-Client
I was about to post the same question. I have exactly the same problem. SNR to a cell phone works, but to MOC number doesn't work. If I call MOC number directly, it works, but not through remote destination profile. You probably followed the same PDF document I did that explains how to set this up. I verified everything and still no luck. I'm running 7.1(5).
if you find anything, please let me know.
430
