Remote Destination Profile
I have a question about the Remote Destination Profiles in Call Manager, there is one attached to a certain number in our customers call manager.
The customer states that after  4 rings it will ring the cell Phone attached to the RDP, now the customer says that internal this works but from external callers this doesn't work.
Is this normal operation, i can imagine something like this must be having activated, and that it isn't default operation just because it's external callers.
Can someone advise on this set-up a bit
Kr,
Yannick Vranckx
VIP Super Bronze
The general issue with
The general issue with external calls is that you have to consider the PSTN rings too..In the past this is what has been the issue. SO you may need to adjust the timers on the RDP/RD to make up for this.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Dear, So for example a number
Dear,
So for example a number has a associated RDP, and when that number receives a external call it will also RDP?.
Kr,
Yannick Vranckx
VIP Super Bronze
Well yes..The call will be
Well yes..The call will be extended to the RD (remote destination) regardless of whether its internal or external..Not sure what you are trying to get across
Well the customer says that
Well the customer says that when a external number calls it it will not forward to the cell phone.
When someone from internal calls, it will transfer to cell phone
Hello!What gateways do you
Hello!
What gateways do you have?
When you activate simple call forward on that IP-phone and call from external, does it work?
Kirill
I have made that change, just
I have made that change, just waiting for the customer to confirm
VIP Super Bronze
You should check logs on your
You should check logs on your gateway to see whats going on..Do a debug and see if the call hits the gateway or not..The debugs you will use will depend on the type of gateway you have..
h323 gateway
debug voip ccapi inout
debug isdn q931
mgcp gateway
debug isdn q931
sip trunk..
debug ccsip messages
Yes, I have spotted a mistake
Yes,
The site is using 1 BRI card with 2 cables, so they have 4 channels i believe. Since they are also making outbount calls it could be that he doesn't make an outbound call because the lines are filled.
I also saw when i called the reception directly it did setup a call towards the cell Phone with the correct "Called Number" but it still said "invalid number format".
If you have h323 gateway/SIP
If you have h323 gateway/SIP trunk, then check:
Call Routing Information - Outbound Calls
Kirill
Is this on the RDP profile
On gateway/trunk config page
105
