10-25-2010 10:55 AM - edited 03-16-2019 01:31 AM
I have the following questions, fxs ports in a remote gateway, can be configured on the CUCM v 5 as a Analog Phone or similar? Can be controlled or registeres these remote fxs port on the CUCM?
Solved! Go to Solution.
10-26-2010 07:26 AM
In the call manager, go to device-->gateways--> choose your gateway model--> then choose the protocol as SCCP
then configure it with the mac-address of the interface that "sccp local" command specifies on the gateway.
http://www.ciscosystems.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_2/ccmcfg/b06gtway.html#wp1360610
please look for sccp gateway config settings in the above link
10-25-2010 11:23 AM
Yes, you can configure them as MGCP, H323 or SCCP ports.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
10-25-2010 11:33 AM
Thanks, Java.
But, How I can enable them whit SCCP?
10-25-2010 11:37 AM
http://www.cisco.com/en/US/partner/docs/ios/12_4t/12_4t2/ht1vg224.html
java
10-26-2010 04:46 AM
but in the configuration of the CUCM, How is the remote gatweway added?
Thanks and Regards
10-26-2010 07:26 AM
10-26-2010 07:42 AM
hope this helps..
10-26-2010 11:33 AM
Thank you very much, your answer is perfect and has helped me.
03-03-2011 07:53 AM
I am trying to configure an FXS port on a remote h.323 gateway. I need to be able to route a translation pattern from the main site to this FXS port. I have CCM 6.1.4. I have configured the port on the router as such in the the remote office.
voice-port 0/3/0
station-id name DeMoss FAX
station-id number 4232672327
dial-peer voice 20 pots
description DeMoss FAX
huntstop
destination-pattern 2099
incoming called-number .
port 0/3/0
How can I point the CCM to this port for DN 2099? I can add the translation pattern later, just want to get the directory number working for testing purposes.
Thanks!
03-03-2011 07:57 AM
You can just create a route pattern of 2099 and point it to the gateway. If you are using H323, you cannot do this with a DN...must be a route pattern.
You can, however, configure the fxs port as SCCP controlled, then assign the DN 2099 to it.
03-03-2011 09:48 AM
Thanks!
I believe that worked!
I looked everywhere and couldn't figure out where I had done the one over a year ago for another office. No wonder I couldn't find the DN.....lol
03-03-2011 10:16 AM
Ok, now how do I tell the FXS port to call out using our main site's PRI?
03-03-2011 10:52 AM
You'll need an H323 dial peer with a session target pointing to CUCM. for example:
dial-peer voice xxx voip
destination-pattern 9.T <--assuming you prefix a 9 for PSTN calls
session target ipv4:x.x.x.x <--cucm
dtmf-relay h245-alpha
codec g711ulaw <--or whatever codec you want to negotiate to cucm. make sure this matches region settings between the fxs router and the pri router
no vad
This will send the call to cucm, so you should have a route pattern in cucm with something like 9.@ (or whatever your local/LD dial plan is). Just make sure the CSS of the fxs gateway contains the partition of the route pattern that points to the PRI.
