Remote MOH on CCME Router
Dear All,
I am configuring a CCM with failback on remote CCME enabled router for MOH running on flash during normal operation. I cant get it work for external to internal call. Anyone can offer help and document on it?
Ray
1 REPLY
Re: Remote MOH on CCME Router
not sure if you have already gone thru this doc:
Integrating Cisco CallManager and Cisco SRST to Use Cisco SRST As a Multicast MOH Resource
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802d1c31.html
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
114
