06-14-2007 04:27 AM - edited 03-14-2019 10:04 PM
HELP!!! I need to set up a remote 7960 phone to connect to our CME via a WAN. On the remote end there is a Linksys RV016 router, the phone has a NAT to a global IP address and the TFTP Server address set to the 7960 is the Gateway address of the 3825(CME)router. On the 3825, I have changed the settings to mtp and codec g729r8 so the remote phone uses CME. I have also tried to NAT the CME Service Module to a Global address but still get the the TFTP Timeout error.
06-14-2007 09:15 AM
As you can see, the MAC specific files are aliased to system:/its/XMLDefault7960.cnf.xml, you do more for this file, copy and paste, edit the IP address, configure into a TFTP server local to the phone.
06-14-2007 12:08 PM
i changed the xml file to look for the CME router and it still timing out
06-14-2007 12:45 PM
I assume that you have placed the file on a local TFTP server, and the phone is loading it correctly.
I also assume that you have configured the phone for static IP address, netmask, default gateway and TFTP address.
If, please verify IP connectivity, eg ping phone from linksys router.
The phone should be able to register to CME if connectivity is working.
You can verify this opening a web browser on a PC local to the phone, and entering ephone IP address as URL. You should see a page including status messages, debug, etc. Please check and post relevant information here.
06-15-2007 06:47 AM
DHCP Server 255.255.255.255
BOOTP Server No
MAC Address 001A2FE8BF70
Host Name SEP001A2FE8BF70
Domain Name SME
IP Address 192.168.1.120
Subnet Mask 255.255.255.0
TFTP Server 1 CME Gateway Router IP
Default Router 1 192.168.1.1
DNS Server 1 205.152.37.23
DNS Server 2 205.152.144.23
Operational VLAN Id
Admin. VLAN Id
CallManager 1 CME Gateway Router
CallManager 2 SRST 192.168.1.1
Directories URL http://CME Gateway Router IP:80/localdirectory
DHCP Enabled No
DHCP Address Released No
Alternate TFTP No
Erase Configuration NO
Idle URL Timer 0
PC Port Disabled NO
SW Port Configuration AUTO
PC Port Configuration AUTO
TFTP Server 2
User Locale
Network Locale United_States
Handset Only Mode No
GARP Enabled Yes
Voice VLAN Enabled Yes
Auto Line Select Enabled No
Video Capability Enabled No
DSCP For Call Control CS3
DSCP For Configuration CS3
DSCP For Services default
Security Mode Non Secure
Web Access Enabled
PC VLAN 0
I was able to ping the phone from the LInksys router (locally) and from the CME Router via the WAN to the Global NAT
06-15-2007 09:44 AM
As I said before, please configure the phone for "TFTP server 1" ato a PC local to the phone, using software like TFTP32 that you can download for free. This PC will have the XML file that you previously copied and edited from CME router.
