Remote Phone Support
HELP!!! I need to set up a remote 7960 phone to connect to our CME via a WAN. On the remote end there is a Linksys RV016 router, the phone has a NAT to a global IP address and the TFTP Server address set to the 7960 is the Gateway address of the 3825(CME)router. On the 3825, I have changed the settings to mtp and codec g729r8 so the remote phone uses CME. I have also tried to NAT the CME Service Module to a Global address but still get the the TFTP Timeout error.
Hall of Fame Super Gold
Re: Remote Phone Support
can you configure port forwarding on the linksys so that TFTP (udp port 69) is forwarded to the phone ?
After that you may still encounter problems because the linksys might not support the SCCP protocol. In that case you can try converting the phone to SIP that is a protocol likely supported by NAT in the linksys.
do i need sip on the CME or the linksys
CME has already support for SIP. Linksys doesn't need anything and should be able to support NAT for SIP already.
What you may need is a SIP image on the 7960 phone, that can be downloaded from CCO in the "voice software" area.
But do this only after you have made the TFTP successful, because this independent from SIP or SCCP.
Failing TFTP, you can configure the phone to use a local TFTP server on which you will copy the XML configuration file generated by the router.
As a recognition to those providing answers, please rate posts using the scrollbox below!
SIPv2 is running on the 3825, should i NAT the service module on the 3825, or is the the gateway address sufficient
what I'm trying to tell you, is that the linksys router is blocking the TFTP replies from the CME router to the phone. This is why you should configure port-forwarding on the linksys router.
The service-module, that I understand to be your CUE, has nothing to do with the above.
I enabled port forwarding udp 69 to the remote phone its still timing out
On the CME router, you can enable "term mon" and "debug tftp-events" to see if at least, the request comes in.
However there is another problem that I didn't mentioned. CME will populate the "processNodeName" in the XML configuration file, with the address that you configured as "ip source" under "telephony-service". This address can be very well an private one, hence unreachable from the Internet.
The workaround, is to cut and paste the XML configuration file (you can see the file name doing "show telephony-service tftp-bindings" and "more ". into a file that you will place on a PC local to the 7960 phone running for example TFTP32, and change the "processNodeName" to the public address for CME.
After that the telephone should register OK, still subject to the potential problem of linksys not supporting SCCP.
All the complications above are the reason why cisco recommends running remote phones over a VPN.
how do i set up a vpn for the phones i wasnt able to find any literature specific to cme and remote phone vpns
You will need a router or PIX/ASA capable of doing VPN on both the remote and central sites.
I have a 3825 with CME 4.0 and a Linksys RV016 they are both capable of setting up a VPN
So go ahead and configure IPsec VPN:
http://cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7b1.html
Note on the CME you will need a k9 image.
Personally, I would try the workarounds exposed before rather than setting a VPN in multi-vendor environment, this is only my opinion however.
As a recognition to those providing answers, please rate useful posts using the scrollbox below!
what is the name of the xml file and where do i get it from
As I said before "show telephony-service tftp-bindings" will tell you all the filenames.
You will see some with mac address, but in reality also the xmldefault will be fine.
Visualize the file with "more ", copy and past into a text file, edit the CME address.
tftp-server system:/its/united_states/7960-tones.xml alias United_States/7960-to
nes.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/
7960-font.xml
7920-font.xml
tftp-server system:/its/united_states/7960-dictionary.xml alias English_United_S
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/
7960-kate.xml
7920-kate.xml
tftp-server system:/its/united_states/SCCP-dictionary.xml alias English_United_S
tftp-server system:/its/XMLDefault-2.cnf.xml alias SEP001A2F35B212.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2FE8BBD0.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2FE8BB8F.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2FE7A42D.cnf.xml
tftp-server system:/its/XMLDefault-2.cnf.xml alias SEP001A2FE7A187.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2FE7A274.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2F44CA78.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2F44C93F.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2F44CB19.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2FE8BF53.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2F35BEF4.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2FE8BF70.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2F35B1F9.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2F35B33D.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2F44CB1D.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2F35AEEE.cnf.xml
tftp-server system:/its/SEPDEFAULT.cnf
tftp-server system:/its/SEPDEFAULT.cnf alias SEPDefault.cnf
tftp-server system:/its/XMLDefault.cnf.xml alias XMLDefault.cnf.xml
tftp-server system:/its/ATADefault.cnf.xml
As you can see, the MAC specific files are aliased to system:/its/XMLDefault7960.cnf.xml, you do more for this file, copy and paste, edit the IP address, configure into a TFTP server local to the phone.
i changed the xml file to look for the CME router and it still timing out
I assume that you have placed the file on a local TFTP server, and the phone is loading it correctly.
I also assume that you have configured the phone for static IP address, netmask, default gateway and TFTP address.
If, please verify IP connectivity, eg ping phone from linksys router.
The phone should be able to register to CME if connectivity is working.
You can verify this opening a web browser on a PC local to the phone, and entering ephone IP address as URL. You should see a page including status messages, debug, etc. Please check and post relevant information here.
DHCP Server 255.255.255.255
BOOTP Server No
MAC Address 001A2FE8BF70
Host Name SEP001A2FE8BF70
Domain Name SME
IP Address 192.168.1.120
Subnet Mask 255.255.255.0
TFTP Server 1 CME Gateway Router IP
Default Router 1 192.168.1.1
DNS Server 1 205.152.37.23
DNS Server 2 205.152.144.23
Operational VLAN Id
Admin. VLAN Id
CallManager 1 CME Gateway Router
CallManager 2 SRST 192.168.1.1
Directories URL http://CME Gateway Router IP:80/localdirectory
DHCP Enabled No
DHCP Address Released No
Alternate TFTP No
Erase Configuration NO
Idle URL Timer 0
PC Port Disabled NO
SW Port Configuration AUTO
PC Port Configuration AUTO
TFTP Server 2
User Locale
Network Locale United_States
Handset Only Mode No
GARP Enabled Yes
Voice VLAN Enabled Yes
Auto Line Select Enabled No
Video Capability Enabled No
DSCP For Call Control CS3
DSCP For Configuration CS3
DSCP For Services default
Security Mode Non Secure
Web Access Enabled
PC VLAN 0
I was able to ping the phone from the LInksys router (locally) and from the CME Router via the WAN to the Global NAT
As I said before, please configure the phone for "TFTP server 1" ato a PC local to the phone, using software like TFTP32 that you can download for free. This PC will have the XML file that you previously copied and edited from CME router.
304
