Community Member
Remote Phones Codec
We have recently moved our phone system to our data center as most of our staff work from home. We've then set up a site-to-site VPN to one of our offices on Cisco ASA5505s which works okay but every know and then we get issues with the voice quality.
Is there a way to set so the remote phones use G729 codec rather than G711?
We are running on CUCM 9.1, if that makes any difference.
Thank you
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hello!You can try to put
Hello!
You can try to put remote phones into Device Pool with  Region (System->Region Information->Region), for example Remote_reg, and configure to use g729 between other regions and inside this region.
Kirill
Hello!
Kirill
Community Member
I've tried that but if I call
I've tried that but if I call from outside, it still shows I am using G711. Would this be down to the settings on the CUBE too?
show call active voice compact
 <callID>  A/O FAX T<sec> Codec       type        Peer Address       IP R<ip>:<udp>
Total call-legs: 4
     62569 ANS     T23    g711ulaw    VOIP        P07808XXXXXX   193.203.210.38:16198
     62570 ORG     T23    g711ulaw    VOIP        P441525XXXXXX   192.168.10.252:19030
     62571 ORG     T23    g711ulaw    VOIP        P   192.168.10.252:16656
     62572 ORG     T23    g711ulaw    VOIP        P    192.168.55.12:21360
You shoukd try to configure
You shoukd try to configure codec under dial-peer, or create 'voice class codec' and apply it to dial-peer.
Saying true, full topology should be known to say exactly, what u need.
Kirill
Community Member
I have the following: voice
voice class codec 1
 codec preference 1 g729r8
 codec preference 2 g711ulaw
and it's then assigned to every dial-peer.
Did you try to remove
Did you try to remove g711ulaw from list?
Community Member
Yup, the call just gets
Yup, the call just gets dropped before being connected.
Do u have hardware transcoder
Do u have hardware transcoder configured?
Community Member
DSP farm, right?  Dspfarm
DSP farm, right?
Dspfarm Profile Configuration
 Profile ID = 3, Service = TRANSCODING, Resource ID = 1
 Profile Description :
 Profile Service Mode : Non Secure
 Profile Admin State : DOWN
 Profile Operation State : DOWN
 Application : None   Status : NOT ASSOCIATED
 Resource Provider : FLEX_DSPRM   Status : NONE
 Number of Resource Configured : 0
 Number of Resource Available : 0
 Codec Configuration: num_of_codecs:1
 Codec : g711ulaw, Maximum Packetization Period : 30
 Profile ID = 1, Service = CONFERENCING, Resource ID = 2
 Profile Admin State : UP
 Profile Operation State : ACTIVE
 Application : SCCP   Status : ASSOCIATED
 Resource Provider : FLEX_DSPRM   Status : UP
 Number of Resource Configured : 8
 Number of Resource Available : 8
 Maximum conference participants : 8
 Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
 Profile ID = 2, Service = MTP, Resource ID = 3
 Resource Provider : NONE   Status : NONE
 Number of Resource Configured : 200
 Number of Resource Available : 200
 Hardware Configured Resources : 0
 Hardware Available Resources : 0
 Software Resources : 200
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    1   28.3.8   UP     N/A  FREE  conf    2      -         -         -
Total number of DSPFARM DSP channel(s) 8
Please, upload 'show run'
Please, upload 'show run' from your CUBE and simple topology, because, I can't understand, how call goes through.
Do u have transcoder, configured in CUCM?
Kirill
Community Member
Kirill,Please see attached.
Kirill,
SIP Provider -> Cisco CUBE 2811 -> CUCM 9.1 -> ASA5505 ->VPN TUNNEL -> ASA5505 -> Cisco IP Phone 8945
Dmitry
Try to check this one:https:/
https://supportforums.cisco.com/document/108431/dial-peer-codec-selection-cucm-region-settings-and-transcoders-sip-deployment
U need 2 scenario. Put CUBE/SIP-trunk in Reg_1 and Phones in Reg_2, and configure g729 codec between them, Xcoder will be invoked.
check if u configured Transcoder in CUCM properly (it's registered and is mentioned in MRGL's for phones and CUBE/SIP-trunk as 1st one)
Kirill
Kirill
Community Member
Thank you. I do not have
Thank you. I do not have Transcoder set under CUCM. Which one do I pick under Transcoder Type?
Cisco Media Termination Point
Cisco IOS Media
Cisco IOS Enhanced Media
Cisco Media Termination Point (WS-SVC-CMM)
I have the phones in Regio2 set to G729. The rest is in Region 1.
Cisco IOS Enhanced
Please, post show run and scrinshot from region page.
Kirill
Community Member
Kirill,I did choose just the
Kirill,
I did choose just the Cisco IOS Media and that worked. Should I change it?
I now get the calls between CUCM and IP Phones in G729.
Thank you very much,
Dmitry
269
