04-30-2009 06:37 AM - edited 03-18-2019 10:20 AM
I would like to add a remote ring in a loud warehouse with flashing lamps. Is there any solution for this with cisco IPphone ?
04-30-2009 07:39 AM
Are you trying to add a shared extension to a phone in the warehouse and you want that line (with the shared extension) to only flash the lamp on the warehosue phone?
04-30-2009 07:49 AM
No,
I have a Ip phone in an office and i want to ring a doorbell in a loud warehouse. So, worker can view with lamp an hear the ringbell to go to the office for take the communication. Do you feel my question ?
04-30-2009 08:01 AM
Maybe you wanna try if there is a doorbell wich is Plugable to analog telephone lines.
If it is possible just configure an ata as share line and plug the bell into the ata.
The bell now rings and you can go to the IPphone
04-30-2009 08:05 AM
Hi Alexandrine,
The Strobe/Loud Ringer will need to be connected to an Analog ATA (as a shared line with IP Phone) or FXS Port. So if the DN in question is 5444 on the IP Phone you would setup an ATA, FXS or VG202 with the same DN (5444) so this analog connection can trip the cct. needed to activate the Strobe/Loud Ringer . I have had good luck with the Viking product line :)
http://www.smarthomeusa.com/Shop/Phone/Viking-Phone-Accessories/Item/BLK-3-EWP/specifications/
http://www.algosolutions.com/pdf/AN-0703.pdf
Hope this helps!
Rob
04-30-2009 08:16 AM
Nice Description Rob, ( 5points )
I was a little bit lazy in describing the possibility of ata's.
greetings
Chris
