remote sip phone registers to cme but out going call fails
   Calling from the remote 9971 fails but incomming call works fine. Any help would be appreciated.
Thanks!
Hall of Fame Super Silver
Re: remote sip phone registers to cme but out going call fails
Do you have proper dial peers and cor?
Can you post your config?
Chris I addedd the configs as an attachment
Hi.
From your config, I can see only hub router with register pools and nothing else regarding voice.
Where calls come from?
Do you have another voice router in infrastructure?
Please let us know.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Thanks for responding,
there are two configs, one from the hub router and one from the remote site. The two are connected over a WAN circuit.
The hub config contains all of the relevant voice info along with tftp files. The remote site config shows the physical and logical port information there are two voice ports 0/1/6 and 0/1/7.
Regards.
Ok now I figure out what you have.
Can you please post the output of a show register pool registered and debug ccsip messages during a failing call?
Carlo
264
