Community Member
Remote telephony
i have this problem:
i have a VPN L2L created by pix and an ASA..in a Side 'A' there ia a CME, the network of Telephony is 172.16.0.x and the data network is 192.168.0.x....in the other side (B)i have network 192.168.1.x..
i try to install a remote telephon on side b, from this telephon i can call external number, but i have problem with internal (are mute)...i haven't problem from datanetwork side A to side B...but i can't ping telephony network from remote side...i try to add this network on vpn connection but nothing to do...
tnx and sorry for my english
Hall of Fame Super Gold
Re: Remote telephony
with IPSec you need to define all the networks that are going over the VPN, this can become complicated, so if you configure the minimum on the ASA/PIX to build a GRE tunnel between the routers, the all the address will pass undisturbed and everything will work.
Hope this helps, plase rate post if it does!
Community Member
i have add the network...but nothing to do...
Community Member
On ASA where there is a ip phone network:
access-list inside_nat0_outbound extended permit ip IP_PHONE_NETWORK
255.255.255.0 LAN_REMOTE 255.255.255.0
access-list outside_20_cryptomap extended permit ip IP_PHONE_NETWORK
nat (inside) 1 IP_PHONE_NETWORK 255.255.255.0
On remote office (PIX)
access-list inside_nat0_outbound extended permit ip LAN_REMOTE
255.255.255.0 IP_PHONE_NETWORK 255.255.255.0
access-list outside_20_cryptomap extended permit ip LAN_REMOTE
Community Member
I have resolve with Gre tunnel..
Very very tnx
119
