10-15-2014 04:29 AM - edited 03-17-2019 12:33 AM
Hi Guys,
I hope all of you are fine :), I am gonna make a small project for our customer and he needs to make a remote conference between two sites, and I suggest to use EX60 but i am confused about to use CUCM or 2900 router and what exactly I need to make this scenario?
Thanks for all
10-15-2014 04:43 AM
The datasheet does not mention CME as a supported platform, so you need to go for CUCM / VCS. Pleas e find details of feature support in the datasheet. Please remember that Multisite option is present with EX90, not with EX60.
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/telepresence-system-ex-series/data_sheet_c78-627494.html
Manish
10-15-2014 05:01 AM
Hi Manish,
thanks, you mean I need CUCM 8 and connect it to Gateway router? which router is good for that?
and i want to make site to site conference with EX60..I cant do that?
thanks
10-15-2014 05:52 AM
You will need cucm 8.6.2 or above to make P2P calls between EX60 endpoints. Regarding router, i would suggest going for one with PVDM's with video conferencing capabilities depending upon your current and future requirements.
Manish
10-15-2014 11:16 AM
Shall I need to buy a sip protocol from ISP company to be able to connect remotely?
