Remote video conference
Hi Guys,
I hope all of you are fine :), I am gonna make a small project for our customer and he needs to make a remote conference between two sites, and I suggest to use EX60 but i am confused about to use CUCM or 2900 router and what exactly I need to make this scenario?
Thanks for all
Hi,The datasheet does not
The datasheet does not mention CME as a supported platform, so you need to go for CUCM / VCS. Pleas e find details of feature support in the datasheet. Please remember that Multisite option is present with EX90, not with EX60.
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/telepresence-system-ex-series/data_sheet_c78-627494.html
Manish
Hi Manish, thanks, you mean I
Hi Manish,
thanks, you mean I need CUCM 8 and connect it to Gateway router? which router is good for that?
and i want to make site to site conference with EX60..I cant do that?
thanks
You will need cucm 8.6.2 or
You will need cucm 8.6.2 or above to make P2P calls between EX60 endpoints. Regarding router, i would suggest going for one with PVDM's with video conferencing capabilities depending upon your current and future requirements.
Manish
Shall I need to buy a sip
Shall I need to buy a sip protocol from ISP company to be able to connect remotely?
33
