Remove 411 Dialing from CME
I have a CME installed and I wanted to know how to remove the outbound dialing of the 411 inforamtion number.
1 ACCEPTED SOLUTION
Re: Remove 411 Dialing from CME
Rudy,
Ok...forget all the translation stuff. I just tested this on my CME in the lab.
just do:
config t
telephony-service
after-hours block pattern 1 9411 7-24
Hope that helped, if so please rate.
Try this,
config t
telephony-service
after-hours block pattern 1 411 7-24
It applied successfully, but it still allows me to dial the number..?? I wrote to memory also..anything I'm missing?
I think the problem is that I have this number configured as a dial-peer..??
dial-peer voice 9411 pots
destination-pattern 9411
port 0/0/0:23
forward-digits 3
Hey Rudy,
I didn't realize it was you. Hows it going. Anyway, try this:
voice translation-rule 1
rule 1 reject /9411/
voice translation-profile reject411
translate called 1
translation-profile outgoing reject411
port 0/0/0:23
Yes Ken it's me...How are you--I see ur still fighting the battles..anyway here's the results and I can still make the calls. What am I missing?
EMI-CME2851#config t
Enter configuration commands, one per line. End with CNTL/Z.
EMI-CME2851(config)#tele
EMI-CME2851(config)#telephony-service
EMI-CME2851(config-telephony)#voice translation-rule 1
EMI-CME2851(cfg-translation-rule)#rule 1 reject /9411/
EMI-CME2851(cfg-translation-rule)#voice translation-profile reject411
EMI-CME2851(cfg-translation-profile)#translate called 1
EMI-CME2851(cfg-translation-profile)#dial-peer voice 9411 pots
EMI-CME2851(config-dial-peer)#translation-profile outgoing reject411
EMI-CME2851(config-dial-peer)#destination-pattern 9411
EMI-CME2851(config-dial-peer)#port 0/0/0:23
EMI-CME2851(config-dial-peer)#end
Can you do a debug voip dialpeer while making the call and post the output here, there may be another dialpeer that is allowing you to make the call.
There was another...
1: Dial-peer Tag=9411
2: Dial-peer Tag=411
026147: Mar 25 15:07:40.619 NewYork: //-1/698D63D59F48/DPM/dpMatchPeersCore:
Calling Number=, Called Number=9411, Peer Info Type=DIALPEER_INFO_SPEECH
026148: Mar 25 15:07:40.619 NewYork: //-1/698D63D59F48/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=9411
026149: Mar 25 15:07:40.619 NewYork: //-1/698D63D59F48/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
026150: Mar 25 15:07:40.619 NewYork: //-1/698D63D59F48/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=411
2: Dial-peer Tag=9411
Rudy,
just do:
config t
telephony-service
Wonderful!!! That was it the first time, but you didn't know the peer was setup using a 9...THanks for your help as always and it was good talking with you again.
Glad that worked and sorry for the runaround...I had to find a CME to test on.
222
