Remove a report from CUCM Cisco Unified Reporting
I did a Unified CM Cluster Overview report in CUCM 8.6 (a cluster with 2 nodes, replication is good) but it took a long time. So I stopped the process.
But when I enter the Unified CM Cluster Overview in Unified Reporting, it shows that generated report. And when I click it, it shows
"ERROR : Fatal error encountered while validating report XML with schema".
My question is : How can I delete a report from Cisco Unified Reporting ?
I searched in Cisco Unified Reporting Administration Guide and I didn't found a way to do it.
EDIT : Well the report was being generated, and the report can finally be displayed. But the question remains open. How can I delete this report ?
Thank you for your answers.
1 ACCEPTED SOLUTION
Hi Mohamed,
Generate a new report, it will overwrite the old one. There is no option to delete it from cucm admin page. If you are concerned about the time it took to generate the report the first time then restart the Database Layer Monitor and Tomcat services before running a fresh report. Tomcat needs to be restarted from CLI of the Pub ( utils service restart Cisco Tomcat ), it is case sensitive.
Manish
Hi Mohamed,
Manish
Thank you
171
