remove/disable dial-peers for 411 calls
bbtekgraf
below is a list of dial-peers that need to be removed (disabled?) from our voice gateway to block outgoing 411 calls. not sure exactly where to start...
disable dial-peer hunting??
dial-peer voice 233 pots
preference 2
destination-pattern 411
incoming called-number ....
direct-inward-dial
port 0/0/0:23
forward-digits 3
dial-peer voice 234 pots
preference 2
destination-pattern 8411
direct-inward-dial
port 0/0/0:23
forward-digits 3
dial-peer voice 243 pots
preference 2
direct-inward-dial
port 0/0/1:23
forward-digits 3
dial-peer voice 244 pots
preference 2
direct-inward-dial
port 0/0/1:23
forward-digits 3
dial-peer voice 253 pots
preference 2
direct-inward-dial
port 1/0:23
forward-digits 3
dial-peer voice 254 pots
preference 2
direct-inward-dial
port 1/0:23
forward-digits 3
thank you for any suggestions.
8 Replies 8
kelvin.blair
Level 5
Level 5
You can simply go under each one of the dialpeers and type shutdown. This will disable those dialpeers. Now this will keep these dialpeers from being matched. There could be another dialpeer that might allowing the same string. If you are requesting to block certain numbers it all depends on the platform you are using. If you are using CME, then take a look at COR (Class of Restriction) in the CME Administration guide. If you are running CM, then all you need to do is create the pattern and specify blocked.
kelvin,
thank you for the reply. our platform is cm 4.1(3) ..fyi.
we will give this a try after hours this evening and i will post an update.
have a great day!
ciao
WOW! thanks for the rating. CM 4.1.3 does have the block feature. It should be located under route option. Select block this pattern and choose call reject.
That should do it..
i did find a list of route patterns, but do not show one listed for 411. do i need to manually set up a route pattern for 411 and then block this pattern - call rejected, and/or type "shutdown" under each specific dial-peer?
i appreciate the assistance, i just want to make sure i do this correctly.
is this correct below in config mode:
>dial-peer voice 233
shutdown
thanks
Yes, but you have to add the dial-peer type after the dial-peer #.
conf t
shut
thank you!
i'll give it a try tonight.
ciao
the shutdown on each 411 dial-peer worked fine.
will the "wr mem" save all of my changes to the compact flash(cisco 2821) in case the router reboots?
