Highlighted
Community Member
Remove leaving * from Voip Dial peer
We have an h323 gateway setup with a Voip dial peer that has a destination pattern that look like the following:
destination-pattern *61.. is there a way that I can remove the * before it sends the digits.
1 ACCEPTED SOLUTION
VIP Purple
Re: Remove leaving * from Voip Dial peer
Sorry, * is a wildcard in translation rules. Try this:
rule 1 /^\*61/ /61/
Hope this helps.
Brandon
VIP Purple
Yes, you can do this with a translation rule.
voice translation-rule 1
rule 1 /^*61/ /61/
voice translation-profile 1
translate called 1
dial-peer voice 1 voip
translation-profile outgoing 1
Hope this helps If so, please rate the post.
Brandon
Community Member
I had tried something like this and the router kicks back an error
rule 2 /^*61//61/ ?% *+ operand could be empty
Looks like it is treating the * like a wild card.
VIP Purple
rule 1 /^\*61/ /61/
Hope this helps.
Brandon
243
