Remove license on CCM 5.1
Can I delete a license file on a CallManager 5.1 ???
Thx a lot ;-)
1 ACCEPTED SOLUTION
Re: Remove license on CCM 5.1
The licenses are located in a specific directory on the CCM (/usr/local/cm/conf/licfiles/), and the solution would be to delete the licence file from the server.
BUT, as you don't have access to the root, you must open a TAC SR, then a Cisco engineer could remove the license file.
br
jp
Why you want to remove the licenses? once uploaded i donot think its doable.
Because I've problems when I restore my CCM and I think that it could be a licenses problem ...
Because the licenses are based on MAC, no ?
br
jp
Ok I seen.
Thx very much jp !
Silver
I just did a "file license delete *" from the CLI. It didn't delete one of the licenses though. Said it was in use. You can also delete one license file. Lookup the name in system -> licensing -> License Unit Report.
oh. Deactivate the CCM service allowed me to delete that one license.
Why do we want to do this? New server, new MAC address. Have to open a TAC case to have them generate new license files with the new MAC address.
299
