Remove old CUCM Cluster in CUOM 8.6
Greetings,
I would like to clean up my CUOM install and remove the cluster that it initially discovered before I rememberd to change the Enterprise Parameter in CUCM from "StandAloneCluster". Now I have two clusters one with my newly named cluster and one with "StandAloneCluster". Can I remove the "StandAloneCluster"?
Mark
Everyone's tags (7)
1 REPLY
Silver
Hi Mark,
     Since CUOM does not add devices as whole clusters but adds them individually my best bet would be to manually delete the servers that make up the "StandAloneCluster" from CUOM (Administration>Device Configuration>Modify/Delete Devices).  Also note that it may take a little while for the changes to be reflected within CUOM.  Thanks.
Please rate helpful posts
Tony
400
