Remove Subscriber from Cluster
Hello
I need to remove our second subscriber from our cluster.
Actually, we have one Publisher 4.1(3) and two Subscribers. The second Subscriber is already off use, so no more Phones are registered on this server.
At the Call Manager Administration page, under the server, the second server is also deleted.
Now I need to delete the Database subscribtion and I have no idea how it works.
I hope that anybody have some experienc about my problem and can help me.
Publisher Server Name: PubSrv
Subscriber 1 Server Name: Sub1Srv
Subscriber 2 Server Name: Sub2Srv
DB Name is: CCM0300
Thanks for your help.
Re: Remove Subscriber from Cluster
Here is a good link for the over all process. It includes a section on how to remove the subscription from SQL.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmcfg/b09remsr.html
Hello
Thank you for your link. After a deeper search on the Cisco.cm site, I got this document.
Now, I'm not sure about the batch files.
I have to put the server name and the database name in this file, but I'm not sure which server name I have to write in these scripts.
One of these is to run on the Publisher and the other one on the second Subscriber.
Do you have an idea or experience with these batch files?
Pascal
The batch files take parameters on the command line so you dont have the edit them. When you run them, you can specify it all from the command line. Based on what you put into the original question, the following command would be run on the publisher to remove the server named Sub2Srv from the CCM0300 DB
RemoveServerFromDB . CCM0300 Sub2Srv
In your case I think thats all that you need to do. If for some reason you want to drop the CCM0300 DB from the Sub2Srv, then you can also run the other batch file on Sub2Srv like this:
RemoveSubscription . CCM0300
^^^^DO NOT RUN THE ABOVE COMMAND ON THE PUBLISHER. Run this only on a subscriber that you are taking out of service.
180
