removing a license from a cucm server
Does anyone know how to remove a license from a cucm server?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Re: removing a license from a cucm server
Hi Mike,
Here are the details :)
file delete
The file delete command includes the parameters dir tftp and license. The file delete command deletes one or more files.
Command Syntax
file delete
dir tftp directory [detail]
license filename [detail]
Parameters
•dir tftp directory deletes the TFTP directory specified by directory. You cannot enter the wildcard character (*) in directory.
•license filename deletes the license file that is specified by license. You can enter the wildcard character (*) as filename to delete all the license files.
Options
•detail-Displays details
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp412067
Hope this helps!
Rob
just to add something to great info from Rob, be aware that's only for 6.1(2) and above. if you have a previous version you'll have to open a TAC case because root access is required to delete the license
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi Mike,
file delete
Command Syntax
file delete
Parameters
Options
Hope this helps!
Rob
java
java
Thank you gentlemen.
6436
