Removing Cisco Default Background
If I remove the cisco default phone background (the blue snow image) from my List.xml file will the first
image listed on that file become the default one when I plug in new phones or will I just get a blank background?
1 REPLY
Re: Removing Cisco Default Background
You cannot remove or modify the image, it's built-in the phone firmware.
This has been asked PLENTY of times before, PLEASE SEARCH NetPro for answers.
Also, even if you don't have any List.xml the image is still and option, because that one is not even listed in the file.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
179
