Removing DID digits in SRST Mode
I'm getting 8 digits from the Telco and we use 7, I'm having a hard time finding out how to remove the first digit.
Example - incoming DID number 47111309 extension number 7111309
Thanks for the help
Everyone's tags (3)
Silver
Re: Removing DID digits in SRST Mode
Use a voice translation-rule/profile and applyy it to an inbound dial-peer that is catching the DID or directly to the port (although this will trim it to 7 digits even when you are not in SRST).
Something like this:
voice translation-rule 1
rule 1 /4711..../ /711..../
voice translation-profile indid
translate called 1
dial-peer voice 1000 pots
incoming called .
direct-inward-dialing
translation-profile in indid
Art
I have tried that but I'm getting an error
(cfg-translation-rule)#rule 1 /4711..../ /711..../
% Invalid input detected at '^' marker.
Silver
Duh!
Sorry I'm rusty..
Try
rule 1 /4711\(....\)/  /711\1/
Art
Worked perfect, thanks
Silver
np - glad to hear it helped
Cheers!
Art
560
