Silver
Removing License from CCM 6.1
Does anyone know how to remove a license from Cisco Unified Communications Manager 6.1?
I was told that no one can get root access, and I am under the assumption that you need root to be able to do this. Is there a way to do this without rebuilding the server?
1 REPLY
Re: Removing License from CCM 6.1
Open a TAC case and reference this bug:
CSCsg28075
Administrator does not have ability to remove licenses from CallManager
they should get the root access with this bug ID and remove the license file
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
146
