Removing mls qos on 3750 interface disables it globally
Hi There,
Has anyone come across an issue with the 3750 series switch where if you remove the QoS configuration at an interface level as follows: -
conf t
int g1/0/2
no mls qos
it removes mls qos globally and this efectively disables QoS on the switch. Is this normal or is this a bug?
Cheers,
Stafford
  • IP Telephony
1 REPLY
Re: Removing mls qos on 3750 interface disables it globally
"mls qos" is a global command.
You can enter commands in other contexts.
Example: You could also enter
int gig0/0/2
no router eigrp 100
That works too :-)
So if you do what you do, you disable "mls qos" on the whole router.
/Martin
207
