Removing MOH in MeetingPlace Express
Is it possible to remove MOH from MeetingPlace Express? I have disable MOH in CCM, but I still have MOH on all conferences until the host joins the call.
Re: Removing MOH in MeetingPlace Express
I assume you are referring to the music in the waiting room for a reservationless meeting? You cannot stop that music like you stop the music for the first person in a scheduled meeting. You can, however, customized the prompt, which the music file is consider also as a prompt. Here is an explaination on customizing prompts:
http://www.cisco.com/en/US/products/ps6533/products_administration_guide_chapter09186a0080579cf2.html#wp1041260
I am interested in stopping the scheduled meeting music. Thanks for the link, I'll review it too.
The music you hear as the first person into a scheduled meeting can be stopped by pressing the * key. You can also customize that music and replace it with silence if that is your preference.
237
