Removing old gateways from CUCM
This may be obvious, but we have some old gateways still in CUCM that are no longer being used.
I would like to remove them.
Is there anything I should look out for in doing something like this?
The addresses are not pingable, except for one, but it is now a completely different device and has no voice config in it.
VIP Super Bronze
You'll want to make sure nothing is dependant upon those gateways (e.g. Route Patterns). Use the related links section in the top-right corner to run a Dependency Records search. For this to work you must also have changed the Enabled Dependency Records Enterprise Parameter to True.
Re: Removing old gateways from CUCM
Just make sure they're not associated to Route Groups or RPs and then you can delete them.
EDIT: For some reason I mixed in my mind a case I have with MRG problems with this and typed MRG instead of RG, LOL.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
134
