Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Removing the digit I prefixed on inbound numbers for external calls CLI...
What a confusing title...:)
Anyway my problem is this:
On inbound calls, I prefix a 9 at the gateway level so that numbers show on the phone display and in missed/received calls with a 9 in front of the number which makes them diallable without editing.
My problem is only in regards to call forwarding calls out externally. Users can forward their desk phones out to their mobiles, and when they do this they will see the CLI of the original caller (feature is enabled by the telco).
Only problem is that when the call is forwarded to the users mobile the CLI is correct except it also has a 9 prefixed onto it.
Is there anyway to remove the 9 that I prefixed from the CLI of outbound calls?
Thanks.
Everyone's tags (4)
Bronze
Re: Removing the digit I prefixed on inbound numbers for externa
Add a translation-profile for outbound calls on the outbound dial peers of your gateway. Match on patterns that start with 9 and remove the 9
Thnaks for replying, i know this is an awkward one.
I should have mentioned that I am using MGCP so a tranlsation profile is not an option on the gateway dial-peer...Need to be able to do it on the CUCM somehow?
Depending on your CUCM version, you should be able to apply a CSS per GW to do Calling Party Transformation Mask using calling party transformation patterns.
Luis A.
402
