Replacement IOS 15.1 command
Is there a IOS 15.X command for the "isdn nsf-service sdn" command which exists in 12.4?
I have 15.1.2T, and it no longer appears as a valid command under interface serial commands
thanks
1 ACCEPTED SOLUTION
Re: Replacement IOS 15.1 command
nsf service is supported only for Primary 4ESS switch type
with user side emulation - isdn protocol-emulate user (default)
Make sure that you  have  isdn switch-type primary-4ess and
DON'T have  isdn protocol-emulate network CLI under D-chan/Serial
interface and you shd see following options....
isdn nsf-service  megacomm
The "isdn nsf-service sdn" command needs to be configured under the
Serial/D-channel interface and is only supported for primary 4ESS switch type.
AFAIK it is supported on IOS 15.1.X
Tere.
Regards, Tere. If you find this post helpful, please rate! :)
Indeed, after setting the switch type, yes, the command is there now.  Thanks for all the replies
378
