Replacing 1k extension from 60xxx to 68xxx
Dear all
We are going to replacing 1000 registered extension from 60xxx to 68xxx
Cucm: 8.6
LDAP :Enabled
Is there any way to do that instead of manually way.
1 ACCEPTED SOLUTION
Re: Replacing 1k extension from 60xxx to 68xxx
Hi Ahmed,
I did it like this:
- Export Phones: all details (under bulk)
- Download the CSV
- open the CSV file with excel and seperate the columns
- Change the DNs and save as CSV
- Upload the CSV
- Import phones: all details with override existing configuration
Thats it, but as I said, test it in lab first.
If you need more infos regarding Bulk, just check here:  http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/8_6_1/bat-861-cm.html
Best regards
Ben
Hi Ahmed,
I have done this already, quite easy:
1.) do an export
2.) change the settings in Excel (you just need to change the line and maybe the lables and external phone mask)
3.) Import with override existing configuration
I would recommend that you do this in a lab or maybe with an limited amount of phones first.
Best regards
Ben
Thanks Ben
Do export for which file ,U mean bulk admin>phones>update lines.
Please give me steps.
Hi Ahmed,
I did it like this:
- Download the CSV
- Upload the CSV
Best regards
Ben
Dear Ben
It gave's a txt file when I open it by excel it show in one Column
How I can separate it.
265
