Replacing the name & surname place in corporate directory
How can I change the place of the name and surname in corporate directory in CCM 6.1? I want the name first showed up after searching someone...
thanks
1 REPLY
Re: Replacing the name & surname place in corporate directory
on linux version the only way would be to create a directory script to achieve that, on windows versions you could modify it but since there is no access in linux this means also a separate server to host the script
java
if this helps, please rate
java
www.cisco.com/go/pdi
123
