Report for a route pattern
Is there a way to get a report from CAR that would show the number of calls for a particular route pattern?
We have some route patterns that are routed to external IVRs. The call comes in on one of 5 PRI/T1 and then are routed out another port to the external IVRs.
The calls appear as Tandem calls when looking at calls for the month, but I would like to be able to pull a report for a particular route pattern or group of route patterns to see the total number of calls.
Doug
Re: Report for a route pattern
no, CAR does not record on which route pattern the call was placed.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Does it not record it on where the call was received from? If I can see the route pattern that received the call that would give me what I need.
these are all the fields that are on the DB
Cisco CallManager 4.1(3) Call Detail Record Definition
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cdr_defs/4_x/cdr413.html
at most you could run a GW utilization report but that's an average report
java
java
Are they the same fields for 6.1.2?
119
