Report for Dial Plan
Hi All, I know that Cisco Unified Communications manager business edition has the capability of generating reports however, I looking to generate a report that will show my dial plan such as what extensions are broadcasting to what extensions or hunt groups. I know that I can look these up myself given an appropriate amount of time however, I thought there would be a simpler way that I could do this and maybe export to text or excel file.
I'm Using CUCMBE 6.1.3
Mike
1 REPLY
Re: Report for Dial Plan
Unfortunately all we have is the dial plan report and some stuff like the route patterns -> RL -> RG -> GWs are only shown via GUI but not when exported.
I'm afraid you'll have to take some time to translate it manually to excel
java
if this helps, please rate
java
www.cisco.com/go/pdi
165
