Community Member
Report of CSS
We are using Cisco CM System version: 8.6.2.20000-2..is it possible to find the report of how many & whcih extn belongs to particular CSS
1 REPLY
HiFor how many CSS, you can
For how many CSS, you can go directly on "Call Routing" --> "Class of Control" --> Calling Search Space.
To know who is using a css you can activate "Dependency Record" function under Enterprise Parameters and, when you are under CSS configuration page, you can use the link on top right to get the result.
Carlo
Please rate all helpful posts "The more you help the more you learn"
16
