Report on Device Pools, Phones
Hello everyone,
in CM 5.x is there a way to run a report that generates all the device pools and then actually lists each phone under that device pool? I am trying to get a list that says "Device Pool 1" and under that have all the phones in that Device Pool listed and then "Device Pool 2" and under that all the phone in that device pool and so on and so forth.
Thanks in advance! All replies rated.
Re: Report on Device Pools, Phones
you can run the device pool report under route plan report to see the info
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks. Under the route plan report I don't see an option for Device Pool. I see several others such as All Patterns, Unassigned DN, etc.
Hall of Fame Super Red
Hi Angel,
Have you tried "Dependency Records" under the Device Pool config page?
Hope this helps!
Rob
Thanks Rob,
not exactly what I hoped for (probably doesn't exists as such) but it does get the job done.
129
