Reporting in MLA
Hi There,
Is there a way we can generate a report and get all the users in MLA who has the access in the CallManager like the superuser access, phoneadmin access and have it in a spreadsheet? Is it possible to get this in SQL? if yes, what is the query syntax?
regards,
Jason
1 REPLY
Green
Re: Reporting in MLA
Hi Jason,
There is no report you can generate with MLA.
You may check MLA logs.
Please try to search
for this: C:\Program Files\Cisco\Trace\MLA, filename Accessxx.log
You may think in Voice Provisioning Tool
84
