Reporting on Specific Extension
Is there a way to run a report on a specific extension to see data on the numbers of calss received and what number calls were transferred to? Thanks!
1 ACCEPTED SOLUTION
Re: Reporting on Specific Extension
yes, you can use CAR for that.
search by user/extension
java
if this helps, please rate
java
www.cisco.com/go/pdi
What version of CCM do you have? Some very useful information is available in the CDR database, and can be accessed either by SQL Query analyzer, or the CAR tool, depending on your CCM version.
Here is a link for CAR info:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/5_1_3/car/carovrvw.html
java
java
115
